Using the self-timer Use the self-timer when you want to be included in a picture, or to ensure a steady Shutter button press. Place the camera on a tripod or flat surface. 1 In any picture-taking mode, press the Info button to turn on the shortcut icons. 2 Press to highlight the self-timer icon. Press to choose a setting: 10 seconds- A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds- A picture is taken after a 2-second delay (for a steady, shutter release on a tripod). 2 shot- The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later. 3 Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures after the delay. Use the same procedure to take a 2- or 10-second self-timer video, but press the Shutter button completely down.
In any still mode, press the Menu button. Press up/down to highlight Self-Timer, then press OK. Press up/down to choose between 10-second, 2-second, and 2-shot (one picture after 10 seconds, a second shot 8 seconds later). Press OK, then the Menu button. Start the self-timer by pressing the shutter release button.
Follow these steps:
1. In any Still mode, tap Settings to open the Settings
panel.
2. Tap Self-Timer/Burst repeatedly, until the desired
Self-timer icon appears at the bottom of the LCD:
10 seconds—A picture is taken after a 10-second
2 seconds—A picture is taken after a 2-second
delay (for a steady, auto-shutter release on a
tripod).
2 shot—The first picture is taken after a 10-second
3. Compose the scene. Press the Shutter button halfway, then completely down.
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
1 In any Still mode, tap Settings to open the Settings panel. 2 Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later. 3 Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures after the delay.
In any Still mode, press down-arrow repeatedly until the self-timer icon appears for the desired setting. Your choices are 10-second delay, 2-second-delay, and 2-shot, where one picture is taken after ten seconds and a second picture eight seconds later.
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer 1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode. 2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor. A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S) : Pressing the shutter button will allow an interval of 2 seconds before the image is taken.
•10SEC self-timer (incomplete circle) : Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle) : A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time. 3. When you press the SHUTTER button, the picture will be taken after the specified time has elapsed.
turns back on as soon as I turn off
I can just leave it on and the Power Saver Mode turns it off
