Ky keypad is locked by security code what can i do 4 unlock 2730c
If you remove off the battery and then switch over , the phone will restart and the keypas should work . If not you can remove the front panel and try to clean the pads and main board. However if the pads lock again you can open phone settings and disable the auto key pad lock facility.Also to open from key pad lock press the menu ( unlock)and the asterik on the left hand corner. It must work. Good day
