Cell Phones Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There are 3 sections where detergent etc goes. Starting from left to right can you tell me which section you should add prewash, detergent & fabric softener. I have a Bosch Maxx Classic
Anonymous
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Aug 12, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
46
Questions
Helped
11691
Points
100
On almost all of them there are labels embossed or engraved into the plastic on the sections. i know this seems obvious, but sometimes they are VERY small and hard to read, i know ours is
  • Grassy1 Sep 30, 2010
    Hi I've got one of these too! AS far as I know, or have been doing, the left one with the two markers like this 'll' is for the detergent, the next one with the flower looking pic, is for the softener and the one with the 'l' marker is for prewash. This did my head in for ages too.
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
How to french braid hair
Before braiding, brush hair to smooth out any knots or tangles.
Starting at the hairline, gather enough hair from top of head to start a regular braid. Divide hair into three equal sections. Hold right section in right hand, left section in left hand, and middle section between thumb and another finger of either hand.
To begin braid, cross right section over middle section, then repeat this move with left section, smoothing hair down as you go. Pull sections fairly tight; you don't want the braid to be loose and come undone.
Before repeating your cross-over motion with the right section, gather a little bit of additional hair from the head's right side, and add it to this section; now cross this larger portion of hair over the middle section of the braid.
Tip: Make sure that the sections of hair you're adding are roughly equal or the braid will look lopsided.
Gather a small section (of equal size to the one you just gathered) of the remaining hair on the left side of your head up and into the left section and cross that over the middle section.
Tip: Slightly dirty hair has less "slip," making it easier to braid.
Repeat steps 4 and 5, adding hair until you've gathered in all additional hair strands. Finish at the bottom with a regular braid.
Once you reach the bottom of the braid, secure the end with a hair band, wrapping it tightly around the hair.
Videos....
www.youtube.com/watch?v=q6M7WzzYPWI
www.youtube.com/watch?v=ujS0VNOXeVg
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Which slot does powder go in?
Prewash powder left, normal was powder right, softener middle syphon section
2helpful
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    1helpful
    2answers
    Old Pioneer SA 700 amp- only left channel works. It will play all inputs- tuner, turntable, etc, but right channel will play none. What's the likely problem? If I can buy the part, I'm not a pro, but I'll...
    I have one of these exact amps, more than likely its the volume pot that will need a clean with some WD40 to clean the dust build up inside, try putting the balance on that channel alone and turn the volume up, if the sound kicks in or trys to kick in, this will be the problem or the track inside the pot maybe very worn on the lower setting, which will need then replacing, remember these amps are around 40 years old and chances are it has done a lot of work, if this doesn't fix the problem, as the previous post said it may be in the power amp section and could just be a dry joint on any of the componets, you can pick up all the componet parts fairly easily and cheaply nowdays anyway, let me know how you go.
    2helpful
    Which tray ( A,B or C) does the fabric conditioner go in?! Also, should it be put in at the beginning of the cycle?! Thank you!
    Put it in tray B. You should see one end of what is a U shaped pipe (upside down) in the tray. The fab con should be put in the tray at the beginning of the wash cycle at the same time you fill the detergent tray.
    Usually from left to right the main detergent / powder goes in the left compartment, the fab con in the centre compartment and the prewash / soaker / starch goes in the right side compartment.
    INDESIT washing machine, no idea what detergent goes where!!
    Head over to the manufacturer's website.
    Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    LG 2277 Liquid Detergent Box & Insert
    please put detergent into the main(left) side of the dispenser
    Top Audiovox Cell Phones Experts
    Mohammad Abumuailek
    Mohammad Abumuailek
    ZJ Limited
    ZJ Limited
    Sean Wright
    Sean Wright
    Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
