Replace the " little white box " . This IS the problem . Take the part with you or your complete model number when getting the part , so you get the correct part .
Shut off the fridge for few hours and check the starter in the compressor which is having a fault. If your compressor is not running well then you will have to see if the starter is heating. If so replace the starter so that the compressor gets better current. You will need help to check the pressure of the gas and the pumping pressure of the compressor. The starter will click and start immediately to run the compressor. If the fridge does not cool the fault will be with the gas pressure or compressor. If not check your defrosting circuit, the timer and the thermostat. SO check this out. Good day
The compressor just keeps on running.The problem is weak
compressor.The refrigerant in the compressor is got low.The compressor
is weak.The compressor needs to be replaced.-------------- The working procedure of
this unit is as follows: --- The compressor starts then it cools the freezer
section. When the freezer reaches its cooling level the defrost cycle starts
functioning. In this cycle the fan in the freezer section starts running and the
cool air in the freezer section is passed to the fridge section and the fridge
section gets cold. The air from freezer to refrigerator passes from the
section, in that section the damper is located.------------ But as you mentioned
that freezer not cooling this indicates problem with compressor.When compressor
cools the freezer section then fridge section gets cold.If freezer section is
not getting properly cold then fridge section will not cool properly/.So the
problem relates to compressor.---------- In the compressor there is a
refrigerant called FREON.With the help of this Freon the compressor cools the
freezer section.Freon is a gaseous type cooling agent.The compressor will stop
cooling when coolant gets leaked from its chamber.--------- Again recharging the
Freon is possible, but the cost for that recharging is approx the cost of new
compressor.So its always advisable to get compressor replaced.Because new
compressor has warranty for few years.------------------ You can get required
parts from from online sites like: --- www.repairclinic.com or from
searspartsdirect online site. --------- This should help.Thanks.Helpmech.
