Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a canon mp730 and since I have replaced my ink cartriges I keep geting a wrong cartridge message. I have checked and rechecked installation and re booted several times to no avail. I have checked and removed the printer head to see if anything looks abnormal also but see no visible problems. If there is an obvious answer please let me know. Other wise I guess it will have to go in to a tec shop. Thankyou!!
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
  • Posted on Aug 12, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
18329
Points
201
Many times , if we use refilled ink cartridge , then also we might get such error messages on the printer display .
Ensure that you are using genuine Canon ink cartridges.. but if the error is after changing to a new set of genuine ink cartridges..
try by cleaning the electrical contacts of both ink cartridge and the printer.. and also do a semi full reset..
2helpful
I keep getting a "wrong
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Re cannon mp730 all in one -I keep getting ?wrong cartridge? error msg. when I followed the solutions that had been posted a month or two ago, removing the cartridge holder, etc. I found that the ink was...
Your print head may be damaged. You might consider replacing it.
Canon suggests pulling the ink wells and also pulling the print head and then reinstalling the whole assembly. They consider this a reset. It is also suggested to replace the printhead which the ink cartridges are housed in. I have done this to remedy bad printing and am considering this $50 purchase as I am dealing with "wrong cartridge" message also. Some have said replacing the printhead remedied this code problem. BUT, i did read one person who said this did NOT work. Right now I am debating whether I should put $50 dollars more into this machine....although this printer has been excellent and many agree.
Comments: Apr 17, 2010 - As a follow up I did fix my "Wrong Cartridge" message by replacing the printhead, I worked and worked at cleaning the old one but finally gave in and anted up the $50. This fixed it! Long live DIYers!
Error message says 'wrong cartridge' Cannot override and the installed cartriges are the correct ones, was working with same installation before
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
3helpful
My Canon Multipass Mp730 says wrong cartridge and the alarm light is blinking. I changed the cartridge, but it's still the same message. I turned it off and unplugged it, still the same message. It won't...
I have the identical problem. After talking with the Canon Service Center here in Arizona, they stated that the problem is with the Printhead, not the ink cartridges. The choices are to buy a new Printhead, which are very hard to find now, or buy a new printer. I found one last Printhead in Tucson, which I can purchase of $50.00, and install it myself. Otherwise, the Service Center can do it for the price of the part, plus $65.00 labor.
Seems like the logical solution is to buy a new printer. The PIXMA MX330 is $99.00 or the PIXMA MX860 is $199.00, which are similar replacements.
I am leaning toward purchasing a new printer. We've had the MP730 for about 5 years.
1helpful
Mp730 message wrong cartridge??? I did install a new ink cartridge, no help so I cleaned and reinstalled the print head after shutting it down for 30 mininutes no help. Still geting the same message....
That message means that you need a new printhead, the holder where your inks go. the part number is QY6-0064-000 around $40.00. easy to change yourself, instructions are included.
1helpful
2answers
I have a Canon multipass mp730. what order do the ink cartriges go in ? starting from the black?
Keeping an order when installing printer cartridges is not necessary.
You can even replace just one cartridge and this would make no difference.
To replace all cartridge you usually start from the right side one and keep following, as it is easier to extract cartridges.
Follow the whole procedure from manual below, under maintainance>>Ink replacement.
Wrong cartridge message pops up and won't print because of it
Even with new cartridges sometimes the pc board that is attached to the cartridge can get dammage,replace the faulty cartridge.
1helpful
Error message "wrong cartridge"
Hi there
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
7helpful
5answers
Display Says Wrong Cartridge
I went to the Canon website http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035 and typed "Wrong Cartridge" in the search portion for the MP730. It listed detailed instructions to remove all ink cartridges, raise the lever to the right on the carrier, and then remove / reseat the "carrier". After that I replaced all cartridges and printed the alignment page. All is working, now.
old marine
old marine
ZJ Limited
ZJ Limited
