Solis Palazzo Espresso Machine Logo
Anonymous Posted on Aug 12, 2010
Solis palazzo does not working. I would like to find a tech in Westchester County, NY area.
Anonymous
Level 3:
  • Master 1,089 Answers
  • Posted on Aug 12, 2010
Anonymous
Master
Level 3:
Answers
1089
Questions
0
Helped
520793
Points
4348
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Need McCulloch 100 series Eager ****** part # 92479 lever/handguard. Any retail store in Westchester County, NY where I can buy this part or any on-line?
Hi acf49,
Here is the web address for Milaca Lawn and Garden's online site:
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF
The McCulloch page will open for you. Click on "parts" tab above "McCulloch" and type in the part number. You'll have to click on your particular model number to see the parts diagram for your saw.
Or, you can go to http://www.mccullochpower.com/ and click on "service locator" and type in your city. I couldn't get the service locator to work for Westchester County, NY. Must need a city or zip. Give it a try!
Thanks for visiting fixya. com,
Handie Andie
While coffee is moming out,water is coming out as well underneath the machine and the steamer Steamer doesnt work. While trying to use the steamer, i noticed that steam is eveyrwhere. How can i fix this...
http://www.juraprofi.de/Solis-Ersatzteile/Dichtungen-O-Ringe/Solis-Dichtung-fuer-die-X100-Bruehgruppe::9015.html
Try this piston seal, it should fix it?
7helpful
Solis Palazzo steam valve knob spins and will not close valve all the way. Knob seems to be stripped.
There is a pin on the valve the knob fits in. The pin might be broken. You probably just need a new valve.
2answers
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
2helpful
Brewer part for solis palazzo
Hi
What part do you need? I have some.
1helpful
Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Standby
I turn mine on in the morning and off at nite.
Top Solis Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
