Bulova Marine Star 96C30 watch Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im am trying to set the time on my watch to current, but how?
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 12, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457749
Points
2634
You can download manual/instructions from the following site:
http://www.bulovaspecialmarkets.com/service/servicecenter.aspx
How to set for 24 hrs.
Dec 29, 2015 • Watches
74helpful
Trying to set correct time n date on deuce watch
On the back of the watch, press the "A" button. Then the top half of the LCD will flash the current "month" setting. Press the "M" button to change the month by 1 month. Press the "M" button until you have the current month.
Then press the "A" button again to change to the watches current date settings. The bottom half of the LCD will flash the current "date" that the watch has been set to. Press the "M" button until you have the current date.
After that, press the "A" button again to select the current hour. Press "M" to select the hour, and when you have the current hour, press the "A" button one more time to select the current minute. Press "M" until you get to the current minute. Once you have the current minute set, press the "A" button again to finalize everything, and your finished!
Dec 19, 2010 • Watches
How do i save the time after im done setting it up??
Hi patelpd111,
Just press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
8helpful
2answers
How to set pokemon c wrist watch?
Hold down the two right buttons. A screen will eventually appear showing the watch's current time with the hour number flashing. Use the top right button to scroll through the numbers, and push the bottom right button to set the number. After you set the time, then the date screen will show with the watch's current date, with the month number flashing. Same buttons do the same thing here.
Sep 30, 2010 • Watches
I got a talking watch but no instructions. Super Storm Talking Alarm Watch. Please help
For Super Storm watch:
Click Mode (upper left) button until either current time blinks (1st click) or current alarm time blinks (2nd click).
Immediately (before the blinking stops, approx 3 seconds), click hours (lower left) and minutes (lower right) to set time. When you pause the clicking, time or alarm will be set.
Sep 01, 2010 • Watches
28helpful
Instructions for pokemon 'c watch' talking watch
Im trying to adjust the time because it stopped when i took it off for a day. Im not sure how i can change it because the adjusting knob is not popping out.
mcdevito75 here, Tissot a very, very great name and watch, a you know most stems pull out to set the time, some watches have a screw down crown this adds to it"s waterproofing as there is a gasket under the crown. Maybe your Tissot has this screw down crown, simply un screw the crown then gently pull up on the crown to set the time. If this fails, see any Jewler for help, doN't mess with the watch to much a syou or anyone could wreck it, and Tissot is very expensive.
1helpful
2answers
My ohsen AD0805 is stuck in military time
For the AD0802 watch, press MODE until the standard time appears, then press START/STOP to set the time and date. In that state, press RESET to change the current setting (hold it to scan values) and MODE to move to the next setting (seconds, then hour, minutes, year, month and day of the month in that order). Press START/STOP again to exit time setting mode. At any time while in time-setting mode, you can press the LIGHT button to toggle 24hour time on and off (the 24H indicator will turn on and off to show the current mode).
I contacted both the eBay seller of the watch and the watch maker and what I got back was a complete joke so I figured it out and made my own manual but there doesn't seem to be any way to attach it to this posting.
Apr 24, 2010 • Watches
4helpful
I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
I answered this for different Fossil watch post, but I believe it will be the same for your watch.
I'll re-post the answer below.
To set the alarm on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
Second, set the correct time. (plus one or two minutes... time to complete this.)
Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
Fourth, push the crown all the way in- to position #0.
The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
To set the alarm SOUND time, pull the crown out to the first click (position #1).
Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
I hope this helps.
9helpful
Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
