Washing Machines Logo
Posted on Apr 29, 2008
Fisher & Paykel Washing Machine IWL12
I have the machine in abnormal condition and often displaying with error code 130 and with one to two times of error 136.
Would you give me hints and the meanings for these codes.
Thanks a lot !
Mr Tang
29-4-2008
  • crouching Aug 10, 2008
    lost my manual wood like to no wot part service code 130 refers to
l blight
Level 1:
  • Contributor 28 Answers
  • Posted on Jun 21, 2008
l blight
Contributor
Level 1:
Answers
28
Questions
0
Helped
21195
Points
39
130 rotary position switch fault 136 motor fault
What is error code 130 fisher & Paykel intuitive eco IW812 ?
the R.P.S or rotory postition sensor is faulty or the connections are corroded
2helpful
Fisher and Paykel error code 107
107. (01101011) Motor Control Module Reset Error
The Display Module has detected that the Motor Control Module has reset when it should
not have. This can be due to a Motor Control Module supply disturbance or microprocessor
failure.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
2helpful
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
