Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Hello, This indicates an Automatic Gain Control (AGC) problem often caused by a dried up capacitor. You will probably need a schematic to go much further. This could be a problem in the tuner, IF, or video amplifiers.
The following assumes you are sure the signal source is strong - try a VCR or other local one (channel 3/4, not the RCA jacks).
(From: Glenn Watkins ([email protected]).) Substitute a variable voltage source for the tuner's AGC voltage. Most of the time the range of AGC is from 1 to 7 volts. If you can get a decent snow free picture with an external AGC source, then the tuner is probably OK.
This is will require you to open the back cover of the television alongside an ohmmeter to read components on the printed circuit board of the television.. Take care
Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
1.In Tools/Options/General Options, check the box beside "Optimal Printing Resolution". 2.Go to File/Printer Setup/Printer Setup. 3.Under "Name" select Broderbund PDF Converter v2.10d 4.Next, go to File/Professional Printing. 5.Select "Save As PDF". 6.At the next screen, type the name of the PDF file you want to save in "Project Name". 7.Under "PDF Resolution", select 600 dpi. 8.Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents). 9.Click on the "Save" button. 10.PrintMaster will save the PDF file to the folder you selected. 11.Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
