Radio Communications Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No talkback - Superstar SS-121 120-Channels Base CB Radio
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
336
Points
Remove D80 to achieve talkback, or put on switch. - www.killercatradio.com
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
465
Points
Cut D80. You can also install a switch to open and close that circuit to turn it on and off. ePowerAmps.com
Anonymous
Level 2:
Champion:
  • Expert 219 Answers
  • Posted on Aug 11, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
219
Questions
Helped
51715
Points
303
A superstar 121 doesn't come with talkback.
  • Anonymous Jul 20, 2012
    Duh. He wants to install talkback. Cut D80. You can also install a switch to open and close that circuit to turn it on and off.
How do I turn off the tutorial on my Motorola xt1575.
TalkBack provides spoken feedback to help you navigate your phone, describing what screens you are on, what you touch and have been activated and de-activated.
To turn TalkBack off / on:
  1. Touch Apps
  2. Touch Settings
  3. Touch Accessibility
  4. Touch TalkBack
  5. Slide the TalkBack switch to the On or Off position
  6. Touch OK
https://support.motorola.com/in/en/solution/MS109215
I need help on my Android ALCATEL one touchA464BG to get TalkBack off of my cellphone
To turn off talkback, go to Settings > Accessibility > double tap TalkBack and choose off.
How to turn off talk back setting
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
See link below
https://support.google.com/accessibility/android/answer/6007123?hl=en
How to get talkback turned off
Hi Michele
Feb 29, 2016 • Cell Phones
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
productforums.google.com/d/topic/nexus/av7djMHBA14
Google
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
android.wonderhowto.com/forum/disable-talk-back-mode-0147617/
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
https://www.youtube.com/watch?v=YDmcLi9kF8w
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
https://www.youtube.com/watch?v=FEei11i4OGg
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
My tr966 has talkback hooked up on it and would like to disconnect it on the board?
Your gonna look in your radio by the transformer for a"d25" diode 25 is what is removed in this radio to add talkback. If you want to disable talkback you need to replace that diode as this radio is not stock with talkback. Someone removed that diode. Diodes only go in one way. Pay attention to the cathode marking on the board and on the diode ( --> ) no smaller than a 1N914 diode as a replacement.
Want to get talkback in a cobra 29
When you key up the mic ungrounds the speaker so you don't hear anything through it, so to get talkback you're putting a 100 ohm 1, or 2 watt resistor between the switched side of the speaker and ground, now when unkeyed the mic grounds the speaker as usual, but when you key the resistor allows a bit of audio from the audio amplifier, not decoded RF, to still get through. I think the pa/ext spkr. jacks are a convenient place to connect it. You may decide to control talkback by running the circut thru a switch like brite / dim switch . Want less talkback, use more resistance, 150 ohm . Too much talkback can become feedback . I hope this helps, J
Disable talkback
one turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
1helpful
5answers
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Top Superstar Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
