Please go through the link mentioned below, it has all the details............
http://www.lanier.com/downloads/manuals/Printers/ap2610_printer_ref.pdf
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Copier Setting Reset
Use the following procedure to reset the copy settings in the UP mode to their defaults.
1. Press User Tools/Counter .
2. Hold down '#' key and then press Copier/Document Server Settings.
3. Press “Yes” when the message prompts you to confirm that you want to reset the Copier Document
Server settings.
4. Press exit when the message tells you that the settings have been reset.
Or you can follow this step to reset the printer:
Step 1
Turn the printer off and unplug the power cord from the printer. Open the top of the printer and remove the toner cartridge or inkjet cartridges.
Step 2
Clean under the toner cartridge if you are working with a laser printer. Use a clean cloth to wipe away any paper dust or dirt from inside the printer. If you have one, a small computer vacuum cleaner can be used. You can also use a hand vac with a fine suction attachment.
Step 3
Clean the print heads if you are working with a Dell inkjet printer. Use a cotton swab to clean around the print heads, then use another cotton swab to clean the bottom of each ink cartridge.
Step 4
Replace the ink or toner cartridge and close the top of the printer. Plug the cord back into the printer and power it on.
Step 5
Print a test page from the printer using your computer. Check the quality of the test print. If the print quality is poor, use the print head cleaning utility supplied by Dell to realign and clean the print heads. The nozzles in the print heads can become clogged, and this utility will help to clear any accumulated ink and keep the printer in top shape.
If you want the user manuel go to the link below:
http://www.lanier.com/downloads/manuals/Printers/lp222cnuserguide.pdf
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
DISPLAY SAYS NEEDS MAINTANENCE- BUT EVERYTHING IS FINE AND I WOULD LIKE TO RESET THE MAINT. COUNT. IF THAT CAN BE DONE. THANKS
