RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Error Codes
Error Error Code Description Code Description
SC320 Polygon Mirror Motor Error/Lock SC354 ID Sensor Error 5 Black TD Sensor Gain Adjustment Error
SC321: No Laser Writing Signal (F-GATE) Error 1 Transfer Belt Signal Error SC355 Yellow TD Sensor Gain Adjustment Error
SC322 1st Laser Synchronization Sig nal Error SC356 Magenta TD Sensor Gain Adjustment Error SC323 LD Drive Current Over SC357 Cyan TD Sensor Gain Adjustment Error
SC324 LD Drive Current Over SC360 Hard Disk Detection Error 1 Development Bias Leak
SC325 Magnification Correction Error SC361 Hard Disk Drive Error 2
SC326 2nd Laser Synchronization Error Revolver HP Sensor Error
F Gate 1 Error SC362 Hard Disk Detection Error 2
SC327 LD Unit Home Position Error 1 IMAC Image Compression Error
F Gate 2 Error SC364 Hard Disk Drive Error
SC328 LD Unit Home Position Error 2 SC365 Image Storage Address Error
SC329 LD Unit Home Position Error 3 LD Unit Pitch Adjustment Error SC366 Hard Disk Bad Sector Maximum
SC330 LD Unit No Initial Setting SC367 Hard Disk (HDD) Bad Sector Maximum SC331 LD Unit Home Position Error 4 SC370 IMAC (Image Compression IC) Input FIFO
Error SC332 LD Unit Present Position Error
Black TD Sensor Detection Error SC335 Polygonal Mirror Motor Error 1
SC371 Yellow TD Sensor Detection Error SC336 Polygonal Mirror Motor Error 2
SC372 IMAC (Image Compression IC) Output FIFO Error
SC337 Polygonal Mirror Motor Error 3 Cyan Sensor Detection Error
SC338 Polygonal Mirror Motor Error 1 SC373 Magenta TD Sensor Detection Error
SC340 TD Sensor Output Error SC374 IMAC (Image Compression IC) Modes
SC341 TD Sensor Adjustment Error 1 Setting Error
Black Development Motor Error Black TD Sensor Lower Detection
Abnormal SC342 TD Sensor Adjustment Error 2
Black Sleeve Motor Lock SC375 Yellow TD Sensor Lower Detection
Abnormal SC343 Yellow Sleeve Motor Lock
SC376 Data Transmission Error SC344 Magenta Sleeve Motor Lock
Cyan TD Sensor Lower Detection SC345 Developer Bias Leak Abnormal
Output Abnormal SC377 Magenta TD Sensor Lower Detectio n
Cyan Sleeve Motor Lock Abnormal
SC346 Color Development Motor Lock SC380 Data Transmission Time Out (Video Input)
SC350 ID Sensor/Pattern Test Erro r 1 Drum Potential Sensor Calibration Error Black TD Sensor Initial Setting Black Development Motor Error
Communication Error SC381 Charge Potential Abnormal
SC351 ID Sensor/VSG Test Error 2 Color Development Motor Error Yellow TD Sensor Initial Setting Error
SC382 Data Transmission Time Out (Video TD Sensor Failure
Output) SC352 ID Sensor/Pattern Edge Detect Error 3 VD Adjustment Error
Magenta TD Sensor Initial Setting Error SC383 VL Adjustment Error
SC353 ID Sensor SC384 Data Transmission Time Out (Connect
LED Current Abnormal at Initialization Error Copy
4 LD Exposure Abnormal
Cyan TD Sensor Initial Setting Error
Error Codes
SC385 ID Sensor VSG Adjustment Error SC452 Transfer Belt Mark Detection Error SC386 Data Transmission Time Out (Hard Disk SC455 Paper Transfer Belt Discharge Corona
Write) Current Leak Amount of Toner on Sensor Pattern Too
SC456 Paper Transfer Unit Position Error Low During ID Pattern Measurement
Development Gamma Error (Black) SC457 Image Transfer Belt Cleaning Unit Position
Error SC387 Development Gamma Error Yellow
Drum Potential Error SC460 Thermistor1 Temperature Error
SC388 Data Transmission Time Out (Hard Disk SC461 Thermistor 2 Error
Read) (-001:open circuit)
Development Gamma Error (Cyan) (-002:short circuit)
SC389 Development Gamma Calculation Error SC471 Transfer Belt H.P. Sensor Error
Development Gamma Error (Magenta) SC490 Toner Supply Motor Leak
SC390 CRC Error/TD Sensor Adjustment Error Exhaust Fan Motor Lock
Development Bias Output Error Main Fan Abnormal
Transfer Bias Paper Attraction Roller Bias SC391 Image Storage Address Error
Leak Error Development Bias Leak
Charge AC Output Error SC492 Cooling Fan Motor Lock
SC392 TD Sensor Initial Setting Error SC493: Exhaust Fan Motor Lock
SC395 Development Output Abnormal SC494 Fuser Exhaust Fan Motor Lock
SC400 Transfer Roller Leak Error SC495 Toner Recycling Unit Error
Image Transfer Belt Bias Error Humidity Sensor
Temperature Detection Error SC401 Transfer Output Abnormal
SC496 Toner Collection Bottle Error SC401- Transfer Roller Leak Detected
Humidity Sensor Error 1
SC497 Toner Recycling Motor Error SC401- Transfer Roller Leak
Toner Collection Motor Error 2: Open Error
SC500 Main Motor/Transport Motor Lock/Fusing SC402 Transfer Roller Leak
Motor Error Open Error
Image Transfer Belt Lubricant Brush SC501 Drawer 1 Lift Motor Malfunction
Current Leak 1st Paper Tray Error
SC403 Transfer Belt Position Sensor Error SC502 2nd (or 1st) Tray Lift Motor Malfunction
2nd Paper Tray Error SC405 Transfer Belt Position Abnormal
SC503 Drawer 3 (or 2nd) Lift Motor Malfunction SC406 Transfer Roller Position Abnormal
3rd Paper Tray Error SC410 Paper Separation Current Leak
SC504 Drawer 4 (or 3rd) Lift Motor Malfunction SC411 Separation Bias Leak Error 4th Paper Tray Error
Paper Discharge Leak SC505 LCC Tray Malfunction (Optional LCC)
SC420 Cleaning Motor Lock SC506 Paper Tray Motor Lock
SC422 PCC Leak SC507 LCT Main/Feed Motor Lock
SC430 Quenching Lamp Error SC508 Rear Fence Drive Error
SC440 Main Motor Lock/Drum Mo tor Lock SC509 Drawer 3 LCT Right Fence Error
SC441 Development Motor Lock Side Fence Error Drum Peripheral Component Motor Lock
SC510 LCT Lower Limit Error SC450 Paper Transfer Bias Current Leak Paper Feed Motor Locks
SC451 Paper Transfer Belt Motor Lock SC511 LCC Motor Lock (Optional LCC)
Error Codes
SC515 Drawer Left Guide Drive Motor M17 Error SC592 Toner Bank Motor Error Tandem Rear Fence Motor Error
SC599 Copy Exit Tray Motor Lock SC516 Drawer 1 Side Guide Motor Error
SC600 Communication Error Between Main SC520 Paper Tray Error/Duplexer Jogger Drive Control And Operation Panel Boards
Motor Error 1 SC601 Communication Error Between BICU &
SC521 Duplexer Jogger Drive Motor Error 2 MCU/Main Control and Scanner ControBoards
SC522 Duplex-Side Fence Jogger HP Error SC602 Communication Error Between BICU &
SC524 Duplex-End Fence Jogger HP Error HDD Controller/Main Control and Tran
Belt Motor Drive Boards SC530 Bypass Feed Motor Lock/fusing Fan Motor
Error SC603 Communication Error within Main Control
Boards SC531 Fuser/Duplexer Reversing Motor Lock
SC604 Serial Signal Error in Main Control Board/ SC541 Fuser Thermistor Open
IDU Communication Error Hot Roller Thermistor Open
SC605 Communication Error Between Main SC542 Fuser Temperature Warm-up Error
Control and IPU Boards Hot Roller Warm up Error
SC610 Communication Time Out Between SBCU/ SC543 Fuser Overheat Error 1 (Software)
BICU & ADF Hot Roller Fusing Lamp Overheat
SC611 Communication Break Error Between the SC544 Fuser Overheat Error 1 (Hardware)
CBCU/BICU & ADF Fuser Low Temperature Abnormal
Hot Roller Fusing Lamp Lo wer Li mit SC612 Communication Command Error Between
Temperature Detected the BICU/SBCU & ADF
SC545 Fuser Lamp Overheat Error 2 SC620 Communication Error Between BICU/
Fuser Ready Temperature Abnormal SBCU & RADF 1/Finisher/Communicatio
Hot Roller Ready Temperature Abnormal Error Between IOB & ADF
SC546 Fuser Ready Temperature Malfunction SC621 Communication Error Between BICU &
Unstable Fusing Temperature RADF 2
Communication Timeout Error between SC547 Zero Cross Signal Malfunction
SBCU & Finisher/Sorter CommunicatioFusing/Hot Roller Temperature Does Not
Error Increase
SC622 Communication Error Between BICU & SC548 Fusing Installation Error
RADF 3/Main Control Board and DisplaFusing Unit Set Error
Editor SC550 Fusing Web End
SC623 Communication Time Out Error Between SC551 Pressure Roller Thermistor Op en
BICU & Paper Tray Unit1-3/Main ConBoard and Projector Unit
SC552 Pressure Roller Warm-up Error SC624 Communication Time Out Error Between
SC553 Pressure Roller Overheat the BICU & LCT/Tray 1-3
SC554 Pressure Roller Low Temperature SC625 Communication Error Between BICU &
Abnormal Finisher 1/FPU
SC555 Pressure Roller Ready Tempera ture SC626: Communication Error Between Abnormal BICU & Finisher 2/LCT/Paper Tray Un
SC557 Pressure Roller Temperature Does not SC627 Communication Break Error Between BICU Increase & LCT
SC558 Zero Cross Signal Abnormal SC630 CSS (RSS) Communication Error Between Line Adapter & CSS Center/RDS
SC590 Exhaust/Fusing Fan Motor Erro r Communication Error
Used Toner Collection Motor Error SC632 Key/Card Counter Device Error 1
SC591 Toner Supply Motor Error SC633 Key/Card Counter Device Error 2
Error Codes
SC634 Key/Card Counter Device Error 3 SC725 Finisher/Sorter Stack Feed Exit Motor Err(1000 Sheet Finisher)
SC635 Communication Error Between BICU & Sorter Stapler Unit Drive Motor Error
Paper Feed Board 1 Key/Card Counter Device Error 4 SC726 Finisher Shift/Lift Motor Error (1000 Sheet
Finisher) SC636 Communication Error Between BICU &
Paper Feed Control PWA SC727 Finisher Stapler Rotation/Hammer Motor Error (500 Sheet Finisher)
SC640 BICU/SBCU Control Data Transfer/ Checksum Error SC728 Finisher Paper Stack Height Error (500
Sheet Finisher) SC641 BICU/SBCU Control Data Transfer
Abnormal/Checksum Error SC729 Finisher Hole Punch Motor Error SC650 Communication Timeout Error Between SC730 Finisher Stapler Position Motor Error
SBCU & Duplex Unit Scanner Motor Abnormal SC670 Engine Response/Start Up Error SC731 Finisher Exit Guide Plate Motor Lock
Output Tray Motor Error (500 Sheet SC672 Controller to Operation Panel
Finisher) Communication Error at Startup
Sorter Tray Shift Motor Error SC690 GAVD Block I2C Bus Error/Application
SC732 Finisher/Sorter Upper Tray/Bin Motor ErroSelection Error
(1000 Sheet Finisher) SC691 GAVD FCI Block 12C Bus Error
SC733 Finisher Lower Tray Lift Motor Error Communication Error Between BICU & Fax
Controller SC734 Finisher Lower Tray Shift Motor Error SC692 CDIC GAVD Block I2C Bus Error SC735 Finisher Pre-stack Tray Paper Motor Error
Communication Error Between Engine SC736 Finisher Exit Guide Plate Motor Error
Board & Print Controller SC737 Finisher Staple Waste Hopper Full (F585)
SC696 Fax Firmware Error SC738 Finisher Shift Tray/Pressure Plate Lift
SC696 Communication Error between Engine Motor Error
Board & Finisher SC739 Finisher Folder Plate Motor Error
SC700 RADF Original Pickup Malfunction DJF Feed-in Motor Abnormal
SC701 RADF Original Pickup Malfunction DJF Belt Drive Abnormal/Bottom Plate
SC740 1,000- sheet Finisher Error in Finisher Area Finisher Front Saddle-Stitch Motor Er
SC741 1,000- sheet Finisher Error in Saddle Error
Stitching Area Optional Paper Tray Unit Error
SC702 RADF Feed Motor Lock LCT Main Motor Error
DJF feed Out Motor Abnormal SC742 LCT Tray Lift Motor
SC703 RADF Transport Motor Lock Finisher Jogger Side Fence Motor Erro
SC704 RADF Original Exit Motor Lock SC750 Cover Interposer Bottom Plate motor Erro
SC705 RADF Bottom Plate Motor Error SC760 ADF Gate Abnormal
SC720 Finisher Upper Transport Roller Motor SC770 Display Editor Abnormal
Error Finisher Jogger Motor Error (500 Sheet
SC790 Projector Lamp Does Not Turn On Finisher)
SC791 Projector Lamp Does Not Turn Off Sorter Main Motor Error
Bridge Communication Error SC721 Sorter Bin Motor Error
SC792 Projector Lamp Overheat SC722 Finisher/Sorter Jogger Motor Error (1000
Finisher Connection Error Sheet Finisher)
SC793 Interchange Connection Error SC724 Finisher/Sorter Stapler Hammer/Head
SC800 Startup Without Video Output End Error Motor Error (1000 Sheet Finisher)
SC804 Startup Without Video Input End
Error Codes
SC818 Watchdog Error SC953 Scanner Image Setting Error SC819 Fatal Kernel Mismatch Error SC954 Printer Image Setting Error SC820 Self-Diagnostic Error: CPU SC955 Memory Setting Error SC821 Self-Diagnostic Error: ASIC SC956 Scanner Setting ID Error
SC822 Self-Diagnostic Error: HDD SC957 Scanner Return ID Error SC823 Self-Diagnostic Error: NIB SC958 Scanner Ready ID Error SC824: Self Diagnostic Error: NVRAM SC959 Printer Setting ID Error SC826 Self-Diagnostic Error: NVRAM/Optional SC960 Printer Return ID Error
NVRAM SC961 Printer Ready ID Error
SC827 Self-Diagnostic Error: RAM SC962 Memory Setting ID Error
SC828 Self-Diagnostic Error: ROM SC963 Memory Finishing ID Error
SC829 Self-Diagnostic Error: Optional RAM SC964 Printer Ready Error
SC835 Self-Diagnostic Error: Parallel Interface/ SC970 Scanner Ready Error
Centronics SC980 HDD Access Error
SC836 Self-Diagnostic Error: Resident Font ROM SC981 HDD Response Error
SC837 Self-Diagnostic Error: Optional Font ROM NVRAM Error
SC838 Self-Diagnostic Error: Clock Generator SC982 HDD Construction Error
SC850 Network I/F Abnormal SC984 HDD Response Error
SC851 IEEE 1394 I/F Abnormal Print Image Data Transfer Error SC860 Startup Withou t HD Conn ection at Main SC985 Scanner Image Data Transfer Error
Power On SC986 Software Write Parameter Setting Error
SC861 Startup Withou t HD Detection at Power Communication Error Between BICU & IOB Key On/Hard Drive Retry Error
SC990 Software Performance Error SC862 Maximum number of Bad Sectors Detected
SC991 Software Continuity Error on HD
SC996 FCU Board Error SC863 Startup without HD Data Lead
Hard Drive Data Read Failure SC997 Application Function Selection Error
SC864 HD Data CRC Error SC998 Application Start Error
SC865 HD Access Error SC999 Program Download Error
SC900 Electronic Total Counter Error SC1101 FCU Error
Black Total Counter Not On SC1102 Handshake error with BICU at Startup
SC901 Mechanical Total Counter Error SC1111 Com mand TX/ RX Error t o/f rom BIC U
Black Total Counter Not Off SC1112 Base Copier's Engine was Reset
SC902 FC Total Counter Does Not Turn Off Lower Toner Counter Error
SC1120 Interface Module Error SC903 FC Total Counter Does Not Turn Off
SC1201 Unrecoverable FCU-SRAM Error SC921 IMB Memory Control Error
SC1207 Unrecoverable Fax Function UpgradeSRAM Error
SC922 IMB DRAM Error SC1299 Software Error
SC924 Optional DRAM Error SC1301 Original Size Error (Fax)
SC925 IMB Non-Connected Error SC1302 Scanner Parameter Error
SC926 Memory Capacity Error SC1303 Software Error (Fax)
SC951 F-gate Signal Error 2/Write Request
SC1304 Software Error (Fax) SC1305 Software Error (Fax) SC1306 Software Error (Fax) SC1308 Software Error (Fax)
SC1310 Software Error SC1311 Software Error SC1312 Software Error SC1313 Software Error (Fax) SC1314 Software Error (Fax) SC1316 Software Error (Fax) SC1318 Software Error (Fax) SC1323 Software Error (Fax)
SC1324 Software Error (Fax) SC1326 Software Error (Fax) SC1328 Software Error (Fax) SC1334 Software Error (Fax) SC1338 Software Error (Fax) SC1401 Software Error/Command Time-out after
Scanning SC1402 Software Error (Fax) SC1403 Software Error (Fax) SC1405 Software Error/Command Time-out during
Storage SC1406 Command Time-out- Original Feed out
SC1410 Software Error (Fax) SC1601 Software Error (Fax) SC2001 Controller Error
Error Codes
Rico aficio "Open side cover to continue" Error please anyone help! :(
what is sc995 error ricoh
mp4500
Copy ricoh 1075
error code 345?
please help me.
Thank u so much mr boiken verli you are great
Polygon engine for sale should [email protected]
Thanh l? 2 em 2075 v? 1 em 1060 m?y ch?y ?m, c?n t??ng ??i ??p, b?n in n?t. Anh em n?o c? nhu c?u alo : 0916537071 - 0964688400
2075 - 18tr
1060 17tr
Copy ricoh mp4500
error code sc 992
please help me.
122 code error
Hello i have ricoh 2075 this machin is bad with error cs 335 please help me
