Http://www.servicematters.com/maytag_library/docs/16010622.pdf
Above is your service manual.
Below is a DIY troubleshooting site to help you along with your service manual to isolate and troubleshoot your issue.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
When this happens usually it is either a sensor, or the Controller board that has been spiked. or the water may not be coming in, because the Inlet Valve may be stuck. You MUST perform the troubleshooting steps, to sort it out.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Kelly
