My wd640 hotpoint aquerius first kept displaying f-01 but i could swich it on and 2 weeks after that every programme just says test and wont do a proper wash. what do i do??
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
F01 on a
Washer Dryer means you have a motor fault. Check the motor and associated
wiring. You may just have a broken wire. Click on the link for more Hotpoint,
Creda and Indesit error
codes. Or use these links for WMA & WM workshop
manuals.
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
The sensor are malfunction/ test the sesor w/multi tester test both terminal if does respond or reading sensor open/ mostly malfunction of drier are sensor /the element will not glow or hot if sensor is the problem.
