SOURCE: Home theater won't start playing DVD
If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
SOURCE: PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
SOURCE: Stuck/jammed discs in a Panasonic SC-PT750 Home Theater system
the suggestion worked. Great.
SOURCE: Spectroniq PHT-300X DVD Home Theater System
Go into the setup for your system and change the 'video' options from "adjust to fit" to "original". worked for me anyway.
