Janome 200E Computerized Sewing Machine Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iam haveing trouable when stitches out letter geting top thread evevn on both side of the letter on the back my frend stitch a letter for me on her 300e for and hers was evevn on both side how can i get this tenison fix i need help
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Sep 13, 2010
Anonymous
Expert
Level 2:
Answers
161
Questions
0
Helped
30960
Points
213
For embroidery the tension needs to be quite loose
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
2answers
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
2helpful
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Tension
change the needle--make sure it's the right one for the fabric
being sewed
adjust the top thread tension--one letter or number at a time till
stitch looks normal--use scrap piece of fabric for test stitching
clean under the needle plate and in the bobbin area for lint
2answers
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
2helpful
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
2answers
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
3answers
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
