Sony DVP-NC85H Multi-disc DVD Player Logo
Posted on Apr 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVP-NC85H - - Shuffle play among several CDs
I would like to load up to 5 CDs and have it play randomly selected tracks from among all the CDs. All I can get it to do is randomly select tracks from only one CD even though up to 5 CDs may be loaded in the carousel. How does one program the DVP-NC85H so that up to 5 CDs can be loaded and it will play randomly selected tracks from among all the CDs in the carousel? Also, is there a way to make such a setup the default play mode, or does it have to be re-programed each time I use it?
Thank you for your time.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 221 Answers
  • Posted on Apr 29, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
221
Questions
0
Helped
59470
Points
503
You should refer to your Product's Operation Manual for help on this. Also, you may goto www.sony.com for more info.
2answers
Skips when playing disc, may go from track one to track ten for no reason.
It sounds like you have the cd on random or shuffle. Look to see if you have a button marked rdm or shuf or some variation of that. If so, try pressing that button to see if random/shuffle turns off.
1helpful
My ipod touch will not play in shuffle mode plays a couple of tracks then stops
you might have reset to shuffle again
The iPod's shuffle feature lets you randomize playback of albums, songs or even your entire music library. You may also find this feature useful if you want to listen to forgotten tracks in your library or discover songs you haven't listened to yet. Disabling the shuffle feature will return playback of a song list to its standard consecutive order. You can enable and disable the shuffle feature at any time.
Navigate to the main menu. Select "Settings." Scroll to the "Shuffle" option. Select "Songs" or "Albums." If you select "Songs," the iPod Classic will shuffle the songs on whatever song list you listen to. If you select "Albums," the iPod Classic will play all songs of an album you select in order and then randomly select another album. Navigate to the playlist or album to which you want to listen. Play a song to initiate the shuffle. b> iPod Nano and iPod Touch Tap the "Songs" icon on your nano home screen. If you are using an iPod Touch, open the "iPod" application. Navigate to the song list, playlist or album you want to play. Tap the "Shuffle" icon at the top of the list to activate the feature.
How to put it on shuffle
Menu Settings >> select Play Mode to select different playback options while in music mode >> Select random to play random tracks within a selected folder or among audio track outside a folder
12helpful
Turn On Shuffle on Coby MP 610 - 8GB
While playing a song, press the Quick Options Menu button (small circle), you will see an option for "REPEAT", choose from:
No Repeat Play tracks in normal order and
no repeat.
One Play the current track repeatedly.
All Play all tracks repeatedly.
RandomAll Play all tracks in random order.
Dir Normal Repeat all tracks in the current
folder.
Dir Rep Repeat all tracks in all folders.
Dir Random Play folders in random order.
3helpful
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Sony Mini Hi-Fi MHC-MG110 no longer chooses CDs at random
Unplug the power for a while and load all CDs. It could solve the playing old paylist.
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
As a CD player - shuffle/random?
The point of buying a 5 disc CD/DVD player is that you can let the machine play randomly through all 5 CD . Where is that button ?
2answers
Cannot stop shuffle function
What program would you use if you , lets say, wanted to play the files on you PC. Que those files up in order on you cmoputers media player, locate an option to create/save a playlist. Save your playlist and transfer the playlist to you player. ----or----- main menu, scroll around to settings and select, then scroll down to sounds, then scroll down to play mode, you have the option of OFF, Repeat one, shuffle, repeat, and shuffle + repeat. I leave mine on shuffle + repeat. Hope this helps
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
