SOURCE: re: kensignton wireless mouse, connected but not working
have you checked the battries in the mouse as the battries that com with the mouse don't last long and have you pressed the connect buttons on receiver and mouse as somtimes usb power receivers loose connection on laptops try this one. hope this works
SOURCE: i pressd the littl button on teh bottom of my mouse and now it dosent work how do i fix it??
you need to press on the receiver that came with the mouse and is connected to your pc. And then press the button on the bottom again
SOURCE: mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
SOURCE: Mouse won't work
I believe I have found a manual in pfd for your specific device. Please let me know if this is the manual you need or if you need further assistance. If it is not the right manual please let me know so I can look for one that fits your needs.
If you would not mind could you please rate my help only if this is the right manual or I have helped you, I really would appreciate it. Thanks
SOURCE: Mouse won't synch with USB
It may be that the mouse is turned off. Try pushing the inset button on the back and the scroll dial at the same time. This turns the mouse on or off and saves battery life. Then push the inset button on the back and the USB receiver button on the end at the same time and it should connect yout to the computer.
