Computers & Internet Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If i'm going to open my 2GB nano imation drive it always send me the note "Please Insert disk into drive F" i can't access my drive in anyways, niether scan, open with, format, etc... please help me.. thank you...
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Aug 11, 2010
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2564685
Points
35672
The memory chip from your drive has died. Nothing can be done to fix that, it's dead, junk it.
2answers
My imatinon nano usb 4gb now only 1 mb what should i do?
I'd go into disk manager, delete any partitions and reformat the flash drive.
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
4 GB Imation pen drive. Reformatted it but only 2GB available now
go to control panel Open Administrative Tool Then Computer Management Under Computer Management Click Disk Management Look for your 4G Volume there and do disk functions
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
I had problem with imation lock
how format flash imation 8 gb write protected
Imation 4GB pen drive is not working................
you will have to re-install the drivers for it i think.
it seems like you pc is finding the drive but just can not access it.
KINGSTONE 2GB pENDRIVE dID NOT WORKING
show my drive but not open it and display insert disk to drive.
2helpful
9answers
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
1helpful
2answers
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
95helpful
12answers
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Grand Canyon Tech
Grand Canyon Tech
