Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color is red to yellow. New bulb put in - Hitachi 50V500 50 in. HD-Ready LCD Television
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Aug 11, 2010
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718544
Points
48227
A LAMP will not cause this problem. Do you have a reddish oval in the middle of the screen on a black and white program?
This model is prone to bad optical light engines (50V500) and there are several class action lawsuits pending right now.
Any discoloration usually means a burnt light engine--give me a better idea what the screen looks like and I will assist you for free.
If my input has helped you know what is wrong rate this solution as "very helpful" as I do this here for free.
Comment on this and I will answer your questions--I am here to help you.
SD TECH
I have a Mitsubishi 65" dlp TV and the picture is green and yellow with no reds or magenta's so would that mean i need a new bulb or does it have something to do with the color wheel
It means that the color wheel or it's encoder is not properly syncing with the controller. It is therefore blanking the DLP chip on the red and blue sections of the color wheel. Clean the color wheel motor and encoder disk, lubricate the motor. This should correct the problem. There may be dirt in the opto-coupler that is reading the color wheel. Be sure to clean it with a vacuum and small brush. Regards.
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2013 • Home
Shows red and yellow line on top of screen
the lcd panels are broken, you need a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
RCA 42" Projection TV
Did you cheak the bulb? I believe those also have red yellow and blue lights to make up the color spectrum you should check all of these bulbs
2answers
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
3helpful
2answers
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
1helpful
Spots on picture screen,color not correct
the picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
1helpful
I am looking for the power wires and gound what color they are
THEY R RED AND BLACK THE YELLOW ONE IS FOR YOUR CLOCK JUST PUT IT WITH YOUR RED RED HOT BLACK GROUND PLEASE RATE THIS
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
2helpful
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
