Computers & Internet Logo
Posted on Aug 10, 2010
My son's PSP will not come on. The green light comes on for a few seconds and then shuts off and nothing. He has only had the unit about 6 weeks.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
99
Points
0
Have you tried charging the unit? That exact thing happens with my PSP when it's not charged.
  • mbboles0373 Aug 18, 2010
    Thank you for your not so helpful solution. Charging the unit would be the obvious solution. Actually, the PSP is damaged or defective and is being returned to be fixed or replaced.
My sony psp not work at all even screen also not display but battery charging ok
Just to be clear.
What happens when you turn the PSP on?
Green light come son for a few seconds then goes off?
Or no green light at all?
2answers
PSP won't turn on
You can try a hard reset. Do this hold the power switch in the upward position for over 10 seconds. This will cause the machine to reboot. Leave it alone for a few minutes then try switching it back on. You may have to flick the switch on twice to start her up again. If it still has a hard time try changing the battery for the one in your sons machine. MAKE SURE that all apps etc are closed on the PSP first and do the hard reset BEFORE you remove the battery on BOTH machines. Ensure PSP is OFF before removing battery. It is possible the battery has been overcharged or just given up. If the console operates with the other battery you know you need get a fresh one. Consider getting a high power one for extended life. Let us know how you get on. May have more info for you.
3helpful
Screen stays black green light comes on for a few seconds.
This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
Please Rate, thanks!
THe PSP will not fully come on....the light turns green but nothing on the screen and then after a few seconds....unit goes off???
It sounds like the firmware is corrupt. You will have to reflash it using a pandora battery and "magic memory stick". You can get one here.
3answers
Green light comes on but nothing else turns on
I'll give you the quick story of what they did. They "bricked" the PSP. This is a term used by all PSP hackers. When you try to hack the system so you can play pirated games on the system, you will occasionally get an error that causes the system to be "bricked". They use the word "brick" because once it happens, the PSP becomes as fun as a brick. You really can't do much about it. Your best bet is to call Sony and see what they can do for you. If you know anyone else that knows what they're doing with PSPs, you could always ask them to fix it for you, but Sony would be the easiest. They won't do it for free, but they will fix it for you. 1-800-345-SONY
Psp
ill put it to ya point blank
he bricked his psp.
you should try to get ahold of another psp that has a cracked screen or somethin and switch the mother boards out...
or take it to a game shop like gamestop and have them put in another motherboard
New psp will not charge
If you have multi meter at home make sure that voltage is coming from the adapter.
if the psp have some battery backup check the battery level when u put on charge...
Go to Settings>> System Settings>> Battery Information>>
If you dont have the equipments to check go your nearest electronic service center or sony showroom. Take your charger with the psp so that they can find out the exact problem
PSP will not turn on
Have you tried ejecting your battery pack? I've had a problem like this. But I don't recall the green light coming on for 15 seconds. Anyway, try ejecting the battery pack and putting it back in. If that doesn't work, then... I tried.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
