running XP, VISTA, W7, W8, w10? (came with W7 is it still W7 OS?(
if this PC fails at other persons wifi homes.?
yes, then the PC is setup wrong or failing.
go to HP and load the correct driver for the 4 wifi chips, used new, only 1 works the other 3 fail.
set the router in your home to use wpa1 or wpa2
turn off wep encryption in the router.
then all devices in your home can connect not just some.
your PC chips support all methods of encryption.,
if the OS is infected with VIRUS this too will kill wifi dead. or worse.
or forget wifi and use the Ethernet cable to router.
at least until you sort the issues.
https://support.hp.com/us-en/drivers/selfservice/hp-g62-200-notebook-pc-series/4150047/model/4229959
