Washing Machines Logo
Posted on Aug 02, 2017
Hi, I have a Maytag Performa PYET444AYW electric dryer. It is not heating up all of the time. I have already taken out the element and had it tested. It was fine. Everytime it quits working I pop open the top and check the fuses and the element and they all appear to have continuity. Most of the time when I shut it back up and plug it in it works again. Do you have any other suggestions I can try?
Jeff Michael
Level 1:
New Friend:
  • Contributor 61 Answers
  • Posted on Nov 03, 2017
 Jeff Michael
Contributor
Level 1:
New Friend:
Answers
61
Questions
Helped
15346
Points
83
Check that the exhaust hose is clean and not obstructed or kinked. Clean it from A to Z every six months!
Does the dryer heating at all?? .
5 Related Answers
A
Anonymous
  • Posted on Sep 17, 2007
SOURCE: Maytag Performa Large Capacity Top-load Washer
Krazytech, Just because your solution didn't work for me does not mean it won't be helpful to someone else who reads it. It was just not helpful to ME...but thanks for the personal attack. You may be a "Master" at technical questions, but you fail miserbly at customer relations. By the way, some people need help with THEIR spelling before posting THEIR negative replies.
A
Anonymous
  • Posted on May 03, 2008
SOURCE: maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Anonymous
  • 121 Answers
  • Posted on Nov 29, 2008
SOURCE: how to get to heating element on dryer
the top will lift up put a putty knife in 2inches from the side and push in and release the tabs the element is in the back it looks like a spring
Anonymous
  • 76 Answers
  • Posted on Dec 02, 2008
SOURCE: Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Anonymous
  • Posted on Dec 04, 2008
SOURCE: No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
I have a maytag performa electric dryer with no heat, checked fuses, replaced heat element and thermostat, any ideas
Have you checked to make certain you have the proper voltage where the dryer is plugged in? 220v? A dryer will run on 110v but requires 220v to heat. Could be a problem with the breaker in the breaker box. If you are not familiar with electricity, I suggest you find someone knowledgeable ie professonial
3helpful
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Maytag performa pav2200 dryer has stopped heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tust
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
2answers
My dryer doesn't appear to be drying as fast as before.
Most times this is because there is a restriction of the air flow leaving the dryer exhaust pipe. This will cause a buildup of heat and cause the high limit to turn the heat off. If clearing the exhaust pipe of crimps, dust or clogged line does not help then let me know. Thanks, Sea Breeze
Dryer element won't get hot
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
1helpful
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Maytag Performa Electric Dryer, model # PYE2200AYW.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Oct 18, 2008 • Dryers
Maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
