The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
