I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
