SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
SOURCE: after cistern refill outflow into toilet bowl
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
SOURCE: I need part number 272.324.KG.1 syphon
I would recommend calling Duravit USA at 1-770-931-3575 as a starting point. After some Q&A they should be able to help you get in touch with the nearest supplier to you so that the part can be ordered. Many manugacturers wil not work directly with the retail public. Also many of them require minimum purchases from their vendors. Y might be required to prepay s&h up front to expedite your item. Sometimes even that is not allowed.
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
SOURCE: Toilet Flush. We have an integrated toilet
Good day!
OK please double check the connection and proper installation of it..
and try to look the cable if you press the button it should go up together with the rubber..
try to adjust the cable to upward..
if you have follow up question just add a comment to give you another idea..
thanks for using fixya and have a nice day!!!
