Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
  • shybabymarie Aug 11, 2010
    i got ur answer but there is also another problem the fridge does not chip out the back is also extremely hot n it also makes a heavy roaring sound, the model fridge is a frt81sghw0 freezer at the top.
  • 1,891 Answers
Sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Posted on Aug 10, 2010
  • dennis dodge Aug 11, 2010
    ck that your fan underneath is coling the coils and clean them if dirty . this will hepl the hot tempt problem but not the leak out the back mm
SOURCE:
Hi there I've got a Fisher & Paykel E240BRS
Try a pipe cleaner! Push the pipe cleaner through the water vent hole at the base of the fridge. That will allow the condensation to evaporate away.
Oct 26, 2013 | Refrigerators
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
Feb 03, 2008 | Whirlpool ET1FHTXM Top Freezer...
Why do I have warm water coming out of my new Fridgidaire french door style fridge
Check to see if the supply line coming into the unit from the rear is not near the compressor. The heat from the compressor will make the water hot.
Oct 17, 2012 | Electrolux EI26SS55GS Stainless Steel ...
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
Have a fridiare fidge( how safe t odrin is hte
well if your worriedabout you could replace it or if there was some way to get vinager to go thru it this clean it out and it's safe for you
May 14, 2010 | Frigidaire FRS26R4A Side by Side...
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Fridgidaire Defrost Water Pan
i found my drain tube was not draining into drain pan, but onto floor
May 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Iced up pipe in back of ge side by side refridgerator
Hi there, yes this will happen when the fridge has been over charged with refrigerant. :) If fridge under warranty get them to come and have a look :)
Sep 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
105 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
