Take the cart out and put it back in there might be some loose connection.
The red light flashing is caused by that bad or damaged cartridge. You can always try cleaning the electrical contacts on the cartridge and inside the ink
cartridge holder assembly, with a damp Q-Tip. Then dry the contacts with a new dry Q-Tip and retry the cartridge. If that does not help, and you still have
your old cartridge, try reinstalling it, even if its empty and see if that printer time out problem goes away.If it goes away replace the cartridge.
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges. This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one? Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This is typical cartridge problem.Which cartridge changed?This printer can print with the only one cartridge inside it, whatever which.Try this: Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges. If this not help your printer has problem in carriage unit and need repair.
