SOURCE: lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
SOURCE: With our panasonic DMC-LZ5, first
http://www.fixya.com/support/t1100571-lumix_dmc_lz5_replace_battery
SOURCE: Panasonic dmc fx-10 digital camera -
The lens may be broken(barrel)replacing kost you about 175,00 euro
SOURCE: The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
SOURCE: camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
