F13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Thank you for your inquiry, raymond bouley!
I understand that your Frigidaire range is displaying an error code of "F13". An "F13" error code typically stands for a bad EEPROM (Erasable Programmable Memory) identification or check sum error. The best way to clear this code is to disconnect power from your range for roughly ten minutes. If you continue to experience an issue it could be a possible that you have a faulty board or wiring harness. I would then recommend having a professional out to perform a diagnosis on your range. Hope this helps. -Matt
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
