I would first check the defrost timer...It may be stuck in defrost position and not advancing to the cooling mode, a common problem...There is a slot, clutched cut, to keep it from being turned in the wrong direction and if you can get to it, place a screw drive in the slot and turn it slowly until you hear a click and/or the compressor start...Some timers are located in back, some in front( bottom), and others inside the refrigerator close to the thermostat...If this does the trick a new timer may be in order, but often it may not happen again...I would replace it anyway to keep from losing food...If the compressor does not start, it may be a bigger problem and usally the overload, especially after a storm with a power off on situation..Overloads burn up from to much amp draw, starting, or trying to start the compressor to soon after it stopping...The compressor pumps up on one side and pulls in on the other creating a pressue difference that must equalize on the off cycle for the compressor to start again...If the off cycle is cut short, like a power off/on situation, the load is to much for it to start until the pressures equalize on the off cycle...Hope this helps.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
