Watches Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scew missing from band that goes attach to the watch
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 07, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
106
Points
0
I have an additional screw that I will gladly trade for an extra link that I need for the KC9004. contact [email protected] if you still want this.
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 10, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457796
Points
2634
I would try a local watch repair place first to see if its a standard type pin. If not you will need to follow this advice.
Watches bought from Kenneth Cole or a Kenneth Cole retailer are covered by a limited lifetime warranty. The warranty does not cover repairs needed because of normal wear and tear. You will need :
  • Padded envelope
  • Check or money order for $8.50
  1. Step 1 Write your name, address, phone number and a description of the problem on a sheet of paper.
  2. Step 2 Put the watch and the paper with your information in a padded envelope.
  3. Step 3 Mail your package to:
    Kenneth Cole Productions Inc.
    Attn: Returns Department
    229 Hollie Drive
    Martinsville, VA 24112
Where can I purchase a watch band for a 40-8191 Armitron watch.
David, Check the attached links for replacement watch band, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Shop Men Women Watches One Watch Many Faces Armitron
Armitron Watch Bands eBay
http://www.target.com/s/armitron+watch+bands+replacement
Kmart com
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Is it difficult to install a curved end watch band ?
I am going to assume you are talking about a leather band. You may need to bend the springbars( the pins that attach your band to the watch). You can do this with two teaspoons. Put the spring bar between the nested spoons and gently squeeze them together. This will facilitate attaching the band.
May 24, 2011 • Watches
6helpful
3answers
Nautica Compass watch
Any local watch repair shop will fix this.
2helpful
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • 1helpful
    2answers
    Missing piece to Luminox 3000 black rubber watch band`
    Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
    Missing screw and band for Casio Alarm Chronograph mod 388
    I am not sure that i have a solution but i am 100% intrested int hat watch mine has the same problem and it was my grandfathers, i sure would like to get a hold of you!!!! mandy laesser at g mail, thanks!
    8helpful
    2answers
    Replacement band for nike watch wa0018 oregon alt
    I wear the smaller, womens' version of the Nike Oregon. Nice watch. I was attracted to it by the replaceable battery feature, but found out the strap goes long before the battery and the joy of ownership goes out the window with the price of Nike wrist-band replacement. I held onto my broken banded watch for awhile, and came up with a solution. First, don't try removing the screws that secure the watch-band pins. Not sure how they work, but I tried several times without luck. Even had a jeweler look at it without success.
    I went to Kohl's and purchased a black velcro Timex replacement band for $8. Again this is the for the smaller version of the Oregon. The width of the timex band in 3/4". It includes a elastic band to secure the watch. This elastic band runs under the back of the watch and over the two pins. It is secured to a faux leather tab (with emblems), which is in turn attached to the velco band. Using a razor knife, I detached the faux leather pad from the velcro band and ran it under the watch pins, then reattached it with a touch of Gorilla glue. Be careful to wipe off any excess as Gorilla glue expands as it dries. Finally I blacked out the Timex advertising with a black felt permanent marker.
    No reason to think this wouldn't work on the larger, mens' version of the same watch.
    Top Kenneth Cole Watches Experts
    Ngoro
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
