Panasonic Lumix DMC-LZ2 Digital Camera Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to unlock memory card on lumix panasonic 7.2 digital camera. I can take a piccccture, however; the card remains locked.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 10, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197899
Points
38521
Move the slide switch on the side of the card.
3helpful
HOW DO i unlock Panasonic Lumix DMCFS42 Digital Camera? When I try to delete photos on camera is says memory card locked. I'm confused to how this even hapened.
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
My digital lumix panasonic was been memory locked what shoud i do to unlocked?
6helpful
Memory card - My memory card is locked.
Is it full? Why not download the pics and then format it in the camera.
12helpful
Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
2helpful
1helpful
Have a message for a locked memory card. We did see the unlock button on the camera by the memory card. Panasonic dmc-ls80
Memory cards have a sliding lock on the side edge...make sure the micro switch is in unlocked positiion.
k
23helpful
Memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
26helpful
2answers
Lumix dmc fs3 troubleshooting - memory card is locked
Take the card out - on the side there is a little white slider with a locked & unlocked padlock symbol - move it to the opposite position it is in now.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
