when your music starts to download a BROWSE option should open you can select your hard drive or a folder in my documents or once its downloaded you could right click select copy and then paste the music into the folder or select the music hold the mouse and drag and drop it into the folder how to make a folder right click in my documents select new folder you can name it then My Music
Nice having you get a PC for yourself, basically if you want to download music onto a file to store on your PC, then you'll have to do any of the following;
1. Get the music files from another location on an external storage like a flash drive,external hard disc, etc. Get the music from say another PC into the external storage and connect the external storage to your computer and transfer the files to your computer. This should not be difficult either.
2. You can connect the computer to the internet and download directed by specifying the location that you need the music file to be downloaded to. Once this is done you can now go ahead and save. One of the websites you can get some music files from included www.rnbxclusive.com
Hello, You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive. Hope it helps.
If not removed safely, external devices can lose information when disconnected.
I recommend using a free recovery tool called Handy Recovery which is normally used to recover files accidentally files on a PC. The application can also be used to try and recover files on your external HD.
Handy recovery: http://www.handyrecovery.com/download.shtml (look for the small button near the bottom that says 'Freeware')
ok...you are connect via usb? when using limewire, window media or itunes,,,,go to options on all them and change the directory where you like to store and retrieve files from...now for the files that you already have on the primary hard drive....go to my computer..you see both drives internal (is your c) and the external is ?) find the music on the c drive ..open it..cut & paste (or click & drag) to the new drive ....to copy this music onto your ipod...make sure you have the latest itunes version (WWW.APPLE.COM) once you have this on the desktop let it scan for all the music on pc....now plug ipod to pc...20-30 seconds your ipod will show up on itunes...look on the bottom of itunes left side (u see the ur ipod)...look up and click on the music folder on pc drive and all the music should now be showing too...click on that same folder drag down to the ipods music folder.......let it load up...it might take awile depending on how much you got .....not never ever pull ipod out always eject the ipod .......then unplug it............................
Thanks for the follow up info.
