There are quite a few reasons the DVD tray in your laptop might fail to open
when you hit the eject button. About the worst thing it can be is if the
motor or gear train failed, which would mean replacing the drive. If the
disc in the drive plays OK, you know that the power and the connector are
fine.
To open your DVD drive, there is a tiny hole on the draw in which to insert a paperclip to manually eject the draw, you will see a small hole by the side of your dvd drive, insert a tiny paper clip or pin inside the hole to manually eject your DVD. Once the This is done, the dvd drive will be open and you can remove your dvd.
Take care.
