SOURCE: faulty nikon d40
same thing has happened to me, only bottom half of the picture displayed and same message comes up. It looks like my best bet is to talk to Nikon about it. Thank you.
SOURCE: nikon d40x shutter problem
May be a weak subject to focus or the flash is not ready when you press the button.
Set the camera to auto(green) mode.Try it with a contrast bright subject for as many time as possible.
If the problem persists turn off the camera and reset the camera using the button near usb connection.
Then go to seller for replacement.
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
