SOURCE: Oil? Gas? Additives?
Small engines like to see SAE30 oil. This is assuming a 4 stroke engine of course (if you have an oil filler spout and dip stick you have a 4 stroke engine). Use regular unleaded gas, and personally I mix STA-BIL into ALL of that gas I use with my small engines. I have too many carburetors to take the chance of needing to rebuild them in the spring.
Manuals for MTD products are here: http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need model and serial numbers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Testimonial: "I have the casing off,and have penitrating oil on the pins and screws ----- tomorrow is an other day!"
SOURCE: I need parts for my
Here is a place that has parts listed for your model chipper/shredder.
http://www.partstree.com/parts/?lc=mtd&mn=24A-452G729+%282007%29
