Honda 50  W Ar Pump 2500 Psi 25 Gpm Pressure Washer Logo
Posted on Aug 08, 2010
190 honda engine only runs on choke? - Honda 50 W Ar Pump 2500 Psi 25 Gpm Pressure Washer
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Aug 29, 2010
Anonymous
Contributor
Level 1:
Answers
21
Questions
Helped
8274
Points
23
Pour a large amount of carburator cleaner into the gas tank
run the engine for five minutes then shut it off and let it sit for a couple of days.
then start it and see if it runs any better
the longer you let it sit with the carb cleaner in it, the better it should run
Does a Honda GCV 190 engine used on pressure washer have an idler screw or how do I idle it. Runs fine but when I let off the trigger it goes dead. Thank you.
https://duckduckgo.com/?t=ffab&q=Honda+GCV+190+engine+idler+screw&atb=v159-1&iax=images&ia=images&iai=https%3A%2F%2Fwww.outdoorking.com%2Fforum%2Fuploads%2Fusergals%2F2013%2F08%2Ffull-2772-12005-honda_gcv160_idle_speed_adjustment.png
1helpful
Choke adjustment
The manual is on this link: http://engines.honda.com/parts-and-support/owners-manuals/GCV160 The manual depends on the serial number. It does not appear to have adjustable choke.
The air intake valve/choke on carberator/ fuel block will not funtion properly , open up, it is continuely closed chokeing no air intake, there is a vacume line not connected, on this carb, does it control...
Firstly, if it's fuel injected, there is no choke. That cold start mode is actuated by the computer. IF it has a carb on it, the choke is opened a little to keep it running with a vacuum line connected from the choke dashpot to the carb base when cold till warm-up, then a heat spring pulls the choke full open. Your gonna have to make up your mid as to whether it fuel injection or natural aspiration with a carburetor.
Why would i have fuel in the oil crank case
too much fuel going through the top of the engine (engine wash).
like having the choke out all the time.....or running too cold.
3helpful
2answers
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
1helpful
How do i adjust the choke on a 2005 honda shadow
http://www.bikebandit.com/houseofmotorcycles/2005-honda-motorcycle-vt750dca-shadow-spirit-carburetor-component-parts/o/m2904sch406961
Not to sure about this one, ok, if the choke wont stay out, then try to trace the choke cable to the carby, have a close look and see which parts move on the carby when you activate the choke, some thing just needs to be tightened up, so that the choke stays on. Also, you say the bike stalls and runs rough, is this with the choke on? If yes, then that is just a sign that you dont need so much choke on. Just try half choke. Do you live in a warm climate? if so, then you dont need much choke . So there is no adjustment really, only by the amount of choke you apply. Also remember, never use the choke if the engine is already warm. And, only use the choke for the first start of the day, when the engine is stone cold. The correct way to to start a cold bike engine is, pull the choke on fully, crank over engine, but DO NOT give it throttle, (this defeats the purpose of using the choke), when engine fires up and starts, slowly push the choke in till a smooth, high idle is acheived. You should be able to ride off slowly, and push the choke off after about a mile.
New honda hrr auto choke hard to start
sounds like it may need the carb clening out, but it could be the auto choke not closing when cold. there was an issue with some of the early auto chokes on the gcv135/160 engines so check to see if the choke flap is in the closed position when starting from cold, run the engine for approx 10-15 minutes and see if the choke flap has opened fully.leave it to go cold and see if the choke flap has returned to the closed position
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
