Televison & Video Logo
Posted on Jan 15, 2018
I have a LD320SS8 Combo. When I try to insert a DVD the DVD starts to load then stops half way. Then when I switch the function back to HDMI 1 the screen tells me there is a disc inside. What should I do to remove the disc which will not eject? That is if there is a disc inside at all, I can not tell.
5 Related Answers
Anonymous
  • 934 Answers
  • Posted on Jun 12, 2007
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Anonymous
  • 4 Answers
  • Posted on Dec 16, 2007
SOURCE: incorrect disc
that means the disc is in the wrong format
Anonymous
  • 121 Answers
  • Posted on Jan 14, 2008
SOURCE: Disc Error:
Take it back to the store if its new or if you bought a warranty and trade it for a new one. If not try calling an electronic store and ask them if they know whats wrongs with it. Be sure to read the instruction manuel for a support phone number and call there too.
Anonymous
  • Posted on Apr 19, 2008
SOURCE: dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
A
Anonymous
  • Posted on Jul 17, 2008
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Philips tv pfl4664 - cant get cable to work using hdmi
Use a HDMI cable (1), connect one end of the cable to the HDMI output of the accessory device and the other end to the HDMI input on the back of the television. Turn on the accessory device, if it is a playback device such as a DVD Player or Recorder insert a pre-recorded DVD, and press [Play] button.
Note: EasyLink requires devices to be connected to the TV by HDMI and that these devices should have HDMI-CEC functionality. To enable EasyLink: Switch on EasyLink on the TV, press the 'MENU' button on the remote control and select TVMenu > Installation > Preferences > Master EasyLink, select On.
NEED INSTRUCTION ON HOW TO PROGRAM MY URC-4021BOO ONE FOR ALL REMOTE
Hello
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
[6] Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code
OK.
Necesito intruciones del este urc-3021bg1 para programar el televisor vizio.
From the Manual:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., DVD/VCR, CBL/SAT,or TV). NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3 . Press and hold SET until the LED (red light) blinks twice, then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
For VIZIO TV try one of the following codes: 1758; 0178; 10178; 627; 502
I am trying to program my urc-4220 all for one remote to my tv and dont know how, i have an older zenith tv and need to know the steps to programing it to my tv
2. On the remote control,press a device key once (i.e.,VCR/PVR,DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once. After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 36) to
you find one that works. If it still doesn’t work, try
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Download the full manual for FREE with codes included from http://www.replacementremotes.com/One-For-All-Manuals/Download-FREE-URC4220-MANUAL-OPERATING-MANUAL.html
Does my Sharp DV-RW34OU dvd recorder+vcr have microphone capability? If so can I purchase a compatible microphone online?
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Cant program dish network remote to my sylvania tv/dvd combo
Not likely will your current remote ever have the capability for your newer model. The code sets are designed into the Dish remote as they were available then and don't 'learn' newer sets.
You might try to find one of the other Funai brand code sets under these names:
Funai, Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Even if you do find one that gives you some functions, I doubt you will find one set for both TV and DVD player so you will have to try individual code sets; one for TV, another for DVD.
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
2helpful
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
