HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
SOURCE: samsung U 600 failing to connect to blue tooth conection
i have purchase a phone with a bluetooth that comes with it. the bluetooth would only light up while it is charging and blue when it is ready. but it will not turn on at all. please help me solve this problem or give me info of where to call. thanks. lucy
