I have a jazzy 1121 electric wheel chair. when turned on the lights scroll and then I have seven lights to blink. I have downloaded a manual but the joy stick does not look the same. i have just the on and off - and speed up and down buttons. can you help?
www.usatechguide.org/itemreview.php?itemid=570 19 posts - ‎16 authors
Medium Back Seat Contoured Medium Back (standard). ... Comments: My jazzyscooter goes forward and side to side but the reverse makes a quick .... Strengths: Tough chair - town I live in doesn't have many curb cuts, but chair will climb ....Maneuvers poorly through (Handicap) doorways, due to rear locked caster wheels.
www.pridemobility.com/...manuals/...jazzy/.../au_jazzy_1... Pride MobilityJAZZY 1122. How a Power Chair Should ... NOTE: This owner's manual is compiled from the latest specifications and product information available at the time of .
yes nplug battery charger in and wait till batterys asre fully charged and turn off,if it doesnt u got water or moisture in the joystick and need a new one
I would think that you have a joystick problem and the only fix is to have it replaced. If Medicare paid for your chair then they will pay 80% of the repair cost. Contact your provider where you got the chair and ask if they can repair it for you or call Roadrunner Mobility @ 1-800-467-2668 to check on your eligibility for a repair and they will send a tech out to check the chair Hope this helps
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Jackie I looked on the Pride Website and threy showed them behind each drive wheel above the motor facing the rear of the chair. Lift to place in freewheel and push down to engage. I hope this helps you
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem. The powerchair going in circles may indicate a motor is bad and needs to be replaced.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
Have someone check if the on board charger light is green after you have charged it all night. Most probably you have a charger problem and this will also create a battery problem since you haven't been charging them with a bad chargger. If medicare purchased your chair then you can find a repair service to repair your chair and Medicare will pay for most of the repair
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
