SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
SOURCE: Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
