Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LG DISHWASHER LDS5811WW HAS ERROR CODE LE.WHAT PART DO I NEED?
    New Friend:
  • 12 Answers
Check for broken wires... if still cant find the problem take motor off and spin the shaft. if there is resistance then you need a new motor
Posted on Dec 15, 2010
  • razman22 Feb 01, 2011
    When removing the impeller assembly is the screw removed clockwise or counterclock-wise?
  • jeremiah chace Jul 31, 2012
    counter clockwise, also called a left hand thread.
3 Suggested Answers
SOURCE:
  • 50 Answers
SOURCE: dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Posted on Jan 05, 2009
  • 373 Answers
SOURCE: error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Posted on Jan 19, 2009
Le error code
LE is "Leak Error" there is a sensor in the motor compartment that detects moisture. this code is activated when a leak is detected in the motor compartment. you will need lg to come repair it as it is a notoriously difficult thing to fix permanently.
Sep 26, 2013 | LG LDF6810ST Stainless Steel Built-in...
We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Apr 30, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
OE Code keeps coming on screen LG Dishwasher LDS5811WW
OE error message is listed in the manual as a drainage problem so first I would check for a clogged line
Jan 28, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Error code LE
Hello and welcome,
locked.
locked.
Remedy:
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
311 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
