Thank you for your inquiry, Charles!
From my understanding you need to clean your Electrolux front load washer. The best way to clean out your washer is to use a hot water cycle and a cup of bleach. I would also recommend cleaning the front gasket using a water and bleach solution. You can visit a home store to see if they offer any type of washing machine cleaner as well. I hope this information is helpful to you. -Matt
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
