Belkin G+ Wireless USB Adapter
What OS (Operating System) are you using??
If it's Windows 2000, XP, Vista or 7, then they MUST have any USB device plugged into the SAME USB port, or it screws up the OS.
Try going to Control Panel (Classic View), then choose SYSTEM to get into Device Manager, go down to USB and see if ANY Belkin adapters are listed (assuming the USB adapter IS Plugged In) - if you see any listed, double-click the adapters and choose to uninstall then.
If that doesn't work, then reboot, pressing F8 repeatedly before the Windows "Splash Screen" shows up. After repeatedly pressing F8 on Boot Up, you should select SAFE MODE (just the choice that only says SAFE MODE). Once SAFE MODE comes up, open Device Manager the same way you did before, then go down again to USB and Delete ANY & ALL Belkin USB adapters listed.
Then reboot and see it it recognizes the Belkin USB adapter now and hopefully will let you setup it's Software.
If you like this, please RATE me .... Thanks
