MY ICEMAKER WONT MAKE ICE. WHEN YOU PUT YOUR FINGER INTO THE ICE MAKER TRAY THERE IS NO WATER. I DO GET WATER FROM THE OUTSIDE OF THE DOOR WHEN YOU DEPRESS THE WATER BAR.
The "motor module's" are notorious for failing. Look at the little white fingers inside the tray area, if they are pointing ANYWHERE but fairly horizontal (or slightly up) you may have a bad module. Take the front plastic cover off and check for broken plastic parts inside, wiggle the large gear to see if you can get it to start turning again, if so (or if the gear is cocked) replace the module. Here's a link to a part supplier. http://tinyurl.com/4qhwo9
Yup, you have a bad motor module. It's easy to replace (3 philips
screws) and you're on your way again! Once you take the screws
out gently pry (wiggle) the module out and then replace it making sure
the fingers are pointing the right way (the module is indexed with a
flat spot so turn the fingers till it lines up with the module when
installing.)
Replaced module and still no ice. what else could be wrong?
The fingers are pointing straight up.
