Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
Posted on Aug 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doe the mixer assembly for a show Moen 782694 get mounted flush with the tile or the backer board
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Aug 09, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
50785
Points
177
Usually flush with the tile. although moen does make an extension kit if you goof and set it too far into the wall
Getting ready to install the Moen DN2160 Curved shower Rod. In reading through the instructions I am confused about what is necessary to install in a tile shower
hi doug. the only issue with tile is that drilling holes in tile requires a special tile cutting drill bit. These are common. I got some last week at a home depot. J.
Jul 08, 2011 • Moen Home
tip
Tips on how to Get ready the Subfloor intended for Ceramic Tile Installs
Ceramic along with porcelain tile are generally among the most rigid supplies intended for floors. They require the subfloor that's which will take into account that, without any fluctuation and also motion. If ceramic and also porcelain tiles are generally set up on the wrinkled surface area, a person manage the risk connected with allowing the tiles to be able to break and also loosen. Locations recommendations on tips on how to get ready the subfloor for a tile assembly.
one. The installation of ceramic tile along with porcelain tile with a real piece
Repair many splits along with wrinkled pads from the real subfloor before the assembly - specifically crucial in the event the tile will be becoming specifically bonded to the real.
If connected with subfloors along with great splits, look at the chance of removing a large portion of real piece along with replacing that using a brand-new one as an alternative to patching all the splits.
Intended for negative splits from the real piece, smooth that along with real filler, and also related substance.
In the event the real subfloor will be brand-new, that have to be still left to be able to treatment 29 days and nights previous to tiling.
Personal hygiene will be paramount. Aside from virtually any surface area supplies, you'll want to take away virtually any grease intrinsic and extrinsic stains, and also alternative contents that have tarnished the piece because most effective it is possible to.
Bare cement backer snowboard can offer powerful, flat working surface to put in tiles on for those who have the real wood subfloor.
only two. The installation of ceramic tile along with porcelain tile with a plywood subfloor
The plywood subfloor have to be structurally seem along with capable to help support the assembly. Tile floors are generally hefty along with tile is a very difficult substance. It is going to bust and also dislodge in the event the surface area bends less than the fill.
Don't forget which you are required an extremely flat working surface to be effective on. If desired, stone dust the plywood into level the subfloor.
Plywood have to be set up over an acceptable subfloor along with have to be a minimum of one 1/8? heavy if put together with the subfloor. Interior-grade plywood along with particleboard are not deemed strong sufficient for a tile assembly.
three. The installation of ceramic tile along with porcelain tile over plastic floors
Non-cushioned plastic along with linoleum which is structurally seem along with unencumbered with high motion can certainly take action just as one suitable subfloor.
Padded plastic seriously isn't the perfect subfloor. You need to take away the plastic ground along with virtually any remnant adhesive utilised to the plastic assembly.
In some instances, it is possible to eliminate the plastic once more, however , not the adhesive. Use the skinny placed which is endorsed from the backer snowboard maker.
If it seems hard, you might want to lay out the backer snowboard along with thinset.
several. The installation of ceramic tile along with porcelain tile over a pre-existing tile ground
It is possible to sometimes keep the tile ground set up along with employ thinset specifically over that, and also take away the tile using a hammer, dependant upon the best way high the ground must sit down relative to be able to doors and also other internal factors.
In the event the current tile ground is focused with a mortar mattress, it really is very difficult to eliminate the tiles with no removing beautiful mortar mattress.
If you're the installation of specifically on the older tile floors, uncertain " up " the existing tile along with stone dust document. Clean using a degreaser along with analyze a little community suddenly intended for bonding.
In addition, test the height from the ground while using height of doors along with showcases. Any good thinset enable you to set up the brand-new ground.
Incorrect to order subfloors
Subfloors in order to avoid intended for tile installs are generally those that are inclined to bend, increase, contract, and also warp. Virtually any high motion may loosen the tile along with soda the grout. Incorrect to order subfloors have to be succeeded and also taken care of using a suitable underlayment. Here's a list of no-go subfloors:
Padded plastic
Border set up plastic
One layered plywood
Flake snowboard
Particleboard
Computer chip snowboard
Hard wood (strip) floors
Luan plywood
OSB planks
Masonite
Linen steel
Which kind of subfloor considering the installation of the ceramic tile on?
Continue to searching for the ideal tile to your renovation venture? Please click here to be able to consider the amazing group ceramic along with porcelain tile.
Wholesale Ceramic Tile from China Manufacturer Best price
on Jul 31, 2015 • Building Materials
tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 • Ridgid Saws
For Danze Sheriton/Plymouth tub/shower faucet, I am finishing the wall with ceramic tile and have set plumbing so plastic guard face will be flush with finished tile. One drawing in the instructions shows...
Don't cover area where plastic guard should be. Make it flush. Some trim is designed to recess into the wall before it's flush. Screws, adapters, trim etc. all will need to be installed when tile is set. Make sure you have nipples extending out from shower head and spout area's as well. If you do this and think ahead a little, you will have fewer problems assembling trim.
Moen 3836...lost installation manual...what size drill bit for the hand held brkt.
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
1helpful
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 • Plumbing
1helpful
Mixer only moves at one speed
Referring to the following parts description:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
The speed is controlled with a combination of the governor assembly #24 which mounts on the motor shaft, and the phase control board #27 which is mounted on the back of the mixer.
They operate in conjunction with item #25, the control plate assembly.
WARNING SHOCK HAZARD. FOLLOW THESE STEPS ONLY IF YOU ARE COMPETENT WORKING AROUND HOT ELECTRICAL COMPONENTS AND FOLLOW ALL SAFETY PRECAUTIONS!!!
Remove the rear cover screw #37 and the rear cover #36 and examine the governor when it is running. Also watch the speed control lever mechanism as you move it from off to the highest speed watching for binding etc.
Make sure that the spring #4 is attached to the bottom of the control plate #25.
If the governor appears to be opening and closing as the speed increases and the linkage is not binding then the problem is most likely the Phase Control Board, item #27.
1helpful
We have two 16 year old shower faucets (house was built in 1993 by Del Webb). Can't tell what model they are. We are guessing they are Moen Legend 3175 (one handle). Problem seems to be pressure balancing...
This is a common problem with this type of shower mixer valve. They are not very good at regulating with pressure change. Your options are somewhat limited to not flushing the toilet or using any other taps when in use, repalce the mixer valve for a modern ceramic unit or installing a 2 vane hot & cold shower pump.
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
