Your motherboard manual will show you what headers to plug them into.
If you dont have the manual, download one from your manufacturers support page.
If you have problems finding your manual, write back with your make and model
SOURCE: where do i connect the front panel MIC connectors in the motherboard
1 2
3 4
5 6
7 8
9 10
Pins 5 and 6 , 6 is ground.
hi check this web
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357135&lc=en&cc=us&product=3644705&dlc=en
SOURCE: how to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
from your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
SOURCE: front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
SOURCE: where do i connect front panel MIC POWER, MIC IN,
I've attache a picture to show you where the jumpers are located on the board, and an explaination of what gets plugged into what.
Good Luck
Thanks
Mark
