Compaq Presario Modem/NIC Combo (212786001)
we have no idea at all what you are running there at all
NO PC stated
NO OS stated (xp,vista/w7/8/10, why?)
An AT%T what? what modem exactly so they did not set it up for you ? no way they would not do that after all its' their modem and you run it from them as a service.
does your unstated PC use Ethernet cable Cat5/6 to the At&T modem or router? that is the fast way to get internet
fastest, most easy, and just plugs in.
your post lacks all key facts,
sorry.
SOURCE: Damaged Modem...
hi please check Dial tone of phone to the end of Modem if it is ok than you need to be Replace Modem it is a problem with Modem...
if this informatiom is useful for you please rate me.......
SOURCE: Internet connection through Internal modem in Laptop
Two solutions:
First for the more experienced:
find the modem on the underside of the laptop unscrew/ re-seat the modem, test, if it works great, if it doesn't try inserting foam, or paper between the modem and the "black case"... if you cant find the modem locate the manual for the laptop.
second (and possiblely the best)
Disable the onboard modem and replace it with a USB one
SOURCE: No Dial tone using Symantec Winfax Pro 10 on Windows 98
We're WinFax support experts and this usually isn't a WinFax specific problem.
Make sure you have proper drivers for Win98 and your modem. Some Conexent (SOFT) modems will allow the installation of incorrect drivers, causing all dialing functions to fail. (NO DIAL TONE/NO CARRIER/ NO Incoming RING detection)
Check your modem via Hyperterminal (or another terminal program)
http://service1.symantec.com/SUPPORT/faxprod.nsf/docid/2001040612202004
SOURCE: error no.797 occurs when i tried to connect to
797 - The modem could not be found.
This
error occurs only in Windows 2000 and XP. The error can occur if the
modem is no longer visible to the system, and may be a problem related
to the modem driver, or system conflicts that cause the modem to work
only some of the time.
In some cases, rebooting the machine may "solve" the problem.
If the modem is an external and is not powered on when the system is booted this error may occur: shut-down, power on the modem & re-boot the system.
If the error persists, check to see if there is an updated driver for your modem.
Thanks.
