Most range tops for gas appliance can be lifted up by hand.
You may have a set of screws located just under the top just above the oven door. You should open your oven door and look up at the bottom of the range top to see if there are in fact any screws, if so remove them then lift.
If no screws you may need a small flat screwdriver to help lift the top. It does have a couple of snap clips that will hold it firm but they are just to hold it from moving during normal use.
Remember to remove your burner grates first.
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
SOURCE: AMANA STOVE
you have an electric problem that it can be from lightening or replace the clock. so u must be sure that gas valve working mostly it must be 24 volt . if u haven't electricity on gas valve check the high limit switch if there is a combination u must change valve
SOURCE: Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
SOURCE: I have an amana gas stove model ARG7800WW . The
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
